VPN ADSL
Answered Question
Mar 4th, 2007
Dears;
I have 2811 router connected to the internet using ADSL connection;
i successfully configured the router to access the internet.
the image which router gas is c2800nm-ipbasek9-mz.124-4.
I need to configure the router to establish VPN tunnel.
which image should i installed .
Overall Rating: 4 (1 ratings)
spremkumar Sun, 03/04/2007 - 22:04
Hi Basheer
Do revert back what kinda vpn you are looking out to configure over here..
Is it going to be static site to site vpn or dynamic vpn from your remote clients ?
Based on the code you have posted its of IP BASE Feature set which requires to be upgraded to Advanced Security Feature set to have the support for IPSEC vpn..
regds
w_basheer Sun, 03/04/2007 - 22:18
Dear;
It's site to site VPN.
i had IPBase and am able to connect to internet and my confugration is OK except the VPN.
when i upgraded my image to advanced security i could not find the ATM interface configuration.
please advice.
