ADSL VPN
Answered Question
Mar 4th, 2007
Dears;
I have 2811 router connected to the internet using ADSL connection;
i successfully configured the router to access the internet.
the image which router gas is c2800nm-ipbasek9-mz.124-4.
I need to configure the router to establish VPN tunnel.
which image should i installed .
Overall Rating: 5 (1 ratings)
kaachary Sun, 03/04/2007 - 04:54
The current image is a K9 image. It will support IPSec VPN.
HTH,
-Kanishka
w_basheer Sun, 03/04/2007 - 04:56
Dear;
it doe not support;
i tried to configure but no commands found.
w_basheer Sun, 03/04/2007 - 12:52
Dear;
i installed the image :
c2800nm-advsecurityk9-mz.124-13.
But i can't configure the ATM interface in my router?
i can't find the interface ATM command.
can you help me please.
