call forward noan and busy
Mar 4th, 2007
I have configured an IP phone (extension 100) for receiving all the incoming calls of my CME 3.3 Then I have configured it to forward calls to another IP phone ( extension 112 )when it's busy or no answered.
The problem is that this command only runs when you call from an other internal extension. i.e. if I call from extension 101 to 100 and it's no answered it forward to 112 correctly.
But the problem is when you call from the PSTN, you call to 964812530, this number is converted to 100, the extension 100 rings, but when it's not answered or busy doesn't jump to 112.
How can I fix it?
This is my config:
voice translation-rule 1
rule 1 /1../ /964812530/
voice translation-rule 3
rule 1 /964812530/ /100/
voice translation-profile SIPout
translate calling 1
voice translation-profile incoming
translate called 3
voip-incoming translation-profile incoming
control-plane
dial-peer voice 100 voip
translation-profile outgoing SIPout
destination-pattern 9........
session protocol sipv2
session target sip-server
codec g711ulaw
dial-peer voice 101 voip
destination-pattern 6........
codec g711ulaw
dial-peer voice 102 voip
destination-pattern 00.T
codec g711ulaw
sip-ua
authentication username xxx password xxx
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar ipv4:213.x.201.x expires 60
sip-server ipv4:213.x.201.x
gatekeeper
shutdown
telephony-service
max-ephones 18
max-dn 20
ip source-address 192.168.3.1 port 2000
auto assign 1 to 18
system message Accesos Web Alternativos AWA
url services http://phone-xml.berbee.com/menu.xml
user-locale ES
network-locale ES
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
moh en_bacd_music_on_hold.au
transfer-system full-consult
transfer-pattern .T
ephone-dn 1 dual-line
number 107 secondary 964812501 no-reg primary
name Angel Gallardo
ephone-dn 2 dual-line
number 101 secondary 964812535 no-reg primary
name Nuria Font
ephone-dn 3 dual-line
number 102 secondary 964812537 no-reg primary
name Jose Seijas
ephone-dn 4 dual-line
number 103 secondary 964812539 no-reg primary
name Oscar Pinto
ephone-dn 5 dual-line
number 104 secondary 964812536 no-reg primary
name Pepe Gallardo
ephone-dn 6 dual-line
number 105 secondary 964812538 no-reg primary
name Pablo Castell
ephone-dn 7 dual-line
number 111 no-reg primary
name diseno
ephone-dn 8 dual-line
number 100 no-reg primary
name Caiana
call-forward busy 112
call-forward noan 112 timeout 10
no huntstop
ephone-dn 9 dual-line
number 108 secondary 964812502 no-reg primary
name Miguel Campos
ephone-dn 10 dual-line
number 109 no-reg primary
ephone-dn 11 dual-line
number 110 no-reg primary
name Comerciales
ephone-dn 12 dual-line
number 106 no-reg primary
name Bea
ephone-dn 13 dual-line
number 112 no-reg primary
name Raquel
--More--
Overall Rating: 2.5 (2 ratings)
rhugo Sun, 03/04/2007 - 06:18
I didn't see any of your circuit detail, but if this is a PRI with DIDs, try removing your voice translation-rule 1 and adding the "dialplna-pattern" which will act similar to the "num-exp"..... then set up a "ephone-hunt 1 sequential" with 100, followed by 101, then send the call to the next extension that can provide coverage. I think you will find that the hunt feature is more suited to what you are trying to do.
Good Luck!
sarenos2006 Sun, 03/04/2007 - 11:18
I don't have PRI, It's connected to a SIP provider.
Can you give a more detailed example of what you are saying?
I'd like to try it but I haven't understand it well.
Paolo Bevilacqua Sun, 03/04/2007 - 13:42
Hola sarenos,
the thing is that when you enable CF and the call in coming via SIP, the router will send a "302 moved temporarily" message with the forwarded extension number. Reasonably, the ITSP will not rehunt to this extension number that is unknown to his dialing plan.
Starting with CME 4.1 (IOS 12.4(11)XJ) you can disable this globally under "voice service voip" or on a per-dial-peer basis with "no supplementary-service sip moved-temporarily", and the transfer will happen transparently to the SIP calling party.
The suggestion about using hunt group I think is reasonable if you constantly use CF on these phone-dn.
Also note, you don't need translation incoming, because you have configured secondary numbers on the ephone-dn.
Remember to rate useful posts!
sarenos2006 Sun, 03/18/2007 - 04:48
Hi, I have now a new cisco router 3825 with (IOS Version 12.4(13r)T ) I think the IOS version is correct for doing what you are saying.
But the problem is it has come with CCME 3.3 so I want to upgrade to CCME 4.1
Please, How can I upgrade to CCME 4.1? Could you explain me? Is it possible to upgrade by the USB ports ?
regards.
john.caston Sun, 03/04/2007 - 22:43
I had a similar issue when connecting a Linksys system to our CCME via a SIP trunk, even though it would ring extensions fine it wasn't being diverted to voicemail. I can't recall exactly what the problem was but I think it was to do with the fact that the phones were running Cisco's standard SCCP protocol, so I think there was something wrong with the translation between SIP and SCCP. I think I loaded SIP firmware on the phones and then it worked OK - not 100% sure?
I also have the same problem between two branches each with CCME and CUE - I think it's the same issue, even though the calls go through to the phone they don't reach the CUE (which is a SIP trunk from the CCME)?
