Firewall failover
Mar 4th, 2007
Dear all,
If I have 2 UR licenses for primary Firewall, can I make one of them as Failover.
TIA
Overall Rating: 5 (1 ratings)
Mohammed Faiz M... Sun, 03/04/2007 - 21:58
Thanks Justin,
I will make the other as standby and test them if it works fine. Is there any special configs for that or same as usual.
Faiz
daviddtran Mon, 03/05/2007 - 06:04
Hi Faiz,
if you have two UR license firewall, you can
run them in Active/Active if you like.
If you decide to make it Active/Standby, get
a FO firewall, it is much cheaper. But
Active/Standby configuration will work with
both UR firewalls but you're wasting your money.
David
CCIE Security
