CME SIP calls forward to CallManager?
Mar 4th, 2007
I'm running CME 3.3 on a 1760 gateway with IOS 12.4(8). This gateway is registered to an external SIP registrar. Making and receiving calls while using a phone registered to CME works OK. Further to this I have CCM 4.2(3) configured with a SIP trunk pointing to this gateway for outbound calls. This works very well outbound, although I have a problem with passing inbound calls from the CME box to CCM. I have attached the config on my gateway and a debug of the dial-peers. As you can see the call does hit the gateway but does not pass it on to Callmanager. Does anyone know how to overcome this problem either by sending the call via SIP or H.323 to callmanager?
dial-peer voice 1 voip
description SIP_Outbound
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
incoming called-number .T
dtmf-relay rtp-nte
no vad
dial-peer voice 2 pots
incoming called-number 843408
direct-inward-dial
dial-peer voice 3 voip
destination-pattern 843408
session target ipv4:192.168.40.6
sip-ua
authentication username 843408 password XXXXXX
no remote-party-id
retry invite 3
retry register 3
registrar dns:draytel.org expires 3600
sip-server dns:draytel.org
telephony-service
max-ephones 1
max-dn 100
max-conferences 4 gain -6
ephone-dn 100
number 843408
name draytel
router#debug voip dialpeer
voip dialpeer default debugging is on
Mar 4 19:56:17.170: //-1/3FAB43C380EE/DPM/dpAssociateIncomingPeerCore:
Calling Number=07748780355, Called Number=843408, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
Mar 4 19:56:17.186: //-1/3FAB43C380EE/DPM/dpMatchPeersCore:
Calling Number=, Called Number=843408, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=843408
Result=Success(0) after DP_MATCH_DEST
Mar 4 19:56:17.190: //-1/3FAB43C380EE/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20001
2: Dial-peer Tag=3
3: Dial-peer Tag=1
router#
router#sh dial-peer voice sum
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
1 voip up up .T 0 syst sip-server
20001 pots up up 843408$ 0 50/0/100
2 pots up up 0 down
3 voip up up 843408 0 syst ipv4:192.168.40.6
Overall Rating: 3 (6 ratings)
Paolo Bevilacqua Sun, 03/04/2007 - 12:51
I think that if you want to route SIP incoming calls to CCM, again with sip or H.323, you may need an IP-to-IP gateway image, that is not available for the 1760.
jrossouw Sun, 03/04/2007 - 12:55
Thanks for that. I take it something like the 2800 series would support that? Could you supply me with the necessary config to achieve this?
Paolo Bevilacqua Sun, 03/04/2007 - 13:04
Under "voice service voip", you will have "allow-connections sip to sip" or "sip to h.323" as necessary.
Under "dial-peer", you will have "codec transparent", unless you are doing transcoding, that requires additional configuration of dspfarm service.
That is basically. Then "debug ccsip message" is your friend to see how the box is talking to the other elements.
You may want to give it a try using a recent 12.4T image even using the current 1760, let us know how it goes.
Please remember to rate useful posts!
Paolo Bevilacqua Sun, 03/04/2007 - 13:47
Thank you for the reduced ranking given to my suggestions, I will try to commensurate with an equal level of support to your future questions.
