Qos Problem for G.HSDSL
Mar 4th, 2007
Here is my running-config file. I run
"CANTAS(config-if-atm-vc)#service-policy output SES" command under PVC 0/35. After this command i dont take any error messages. But this service doesn't work.When I check running-config again i can not see this command under pvc. And i run "show policy-map interface atm 0/0.1" but see nothing. How can i start this service correctly. Thank for everthing.
paul_alexander Sun, 03/04/2007 - 22:53
Your ATM interface doesnt have the right configuration for a service-policy
Under the PVC you need to apply L2 QoS. Specify cbr or vbr for the interface speed.
The other thing that may be stopping you is the "atm route-bridge ip". I'm not entirely sure if that makes a difference. But if it still doesn't work then you will need remove that statement and get the remote end to adjust its configuration too.
