Max Call Handlers in Unity
Mar 4th, 2007
Anyone know what the maximum number of Call Handlers supported on Unity 4.x?
Tommer Catlin Mon, 03/05/2007 - 10:31
I dont think there is a max in CallHandlers, but you are limited in the number of Ports you can use for CallHandlers. If you have 96 ports being used, the 97th caller will get a busy signal.
In really large enviroments, it may be advisable to configure a seperate Unity server just for CallHandlers if you are trying to route many things from incoming remote sites. (hub and spoke designs)
