NAC framework deployment
Mar 4th, 2007
Hi All,
I have a problem with the NAC deployment.
Currently i try to setup the lab for deploy 802.1x solution.
I have follow the step configure the NAD (switch), ACS,....but i still receive the error message that mention i don't have certificate in personal store as credential for authentication.
Anyone can help?
Vivek Santuka Mon, 03/05/2007 - 06:46
CTA 802.1x supplicant uses only EAP-FAST.
So On the client you need to either uncheck "validate server certificate" on take the ACS Certificate/Root certificate of the CA Server and add it in the store. To add in the store use :-
ctacert /ui 5 /add "path to certificate" /store "root"
Vivek
chenyokechuan Mon, 03/05/2007 - 17:02
Thanks for help, may i know how to disable "validate server certificate" on the CTA agent? For the CA, it is MUST be a root CA? if i plan to test it on lab environment, can i setup a standalone/standard CA?
Chen
Vivek Santuka Tue, 03/06/2007 - 05:26
Chen,
You can setup a standalone CA or even use the self signed certificate from ACS.
Vivek
