Link State and its routing metric
Answered Question
Mar 5th, 2007
I am sure that link-state uses cost (108 / bandwidth) as its routing metric.
I have been in a discussion that link-state uses delay and load , reliability in its routing metric as well (i disagreed).
I could not find solid authenticated document for proof through my search. Yes I found document to proof that link-state uses cost.
Any comment ?
Correct Answer by Jon Marshall about 9 years 7 months ago
if you are talking about OSPF then yes it uses cost as it metric with the bandwidth as the variable factor.
Delay and load are two of the metrics used by IGRP/EIGRP.
Jon
Overall Rating: 4 (1 ratings)
Correct Answer
Jon Marshall Mon, 03/05/2007 - 00:29
Jon
zillah2004 Mon, 03/05/2007 - 00:31
>>if you are talking about OSPF<<
Yes.
What about other ? could you please explain ?
Jon Marshall Mon, 03/05/2007 - 00:42
IGRP/EIGRP uses 4 characteristics to determine the metric of a route
1) bandwidth
2) delay
3) load
4) reliability
By default the 2 that are used in the route metric calcultaion are bandwidth and delay.
Jon
zillah2004 Mon, 03/05/2007 - 00:47
Thanks Jon for that , Yes i am aware of that.
I thought mistakenly, that you was talking about other link-state protocols, therefore i asked like what ?
Sorry for confusion
Jon Marshall Mon, 03/05/2007 - 00:54
Oops, my mistake. No i was just referring to OSPF when talking about link state.
Jon
