Unity express restore question
Answered Question
Mar 5th, 2007
Hello, if I have a backup category all of a Cisco Unity express module, can I restore this on another module with a higher software version ? Or do I need first to install the same software as the backup version and do the restore procedure afterwards ?
Many Thanks
Dirk
Correct Answer by Brandon Buffin about 9 years 6 months ago
Dirk,
You can restore to a higher version as this is the process used when upgrading CUE. You backup the current configuration, upgrade the software and restore the data.
Also, keep in mind that the license file is not part of the backup, so you will need to install the license file on the new module before restoring the data.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Mon, 03/05/2007 - 06:29
Dirk,
Brandon
sequan_01 Mon, 03/05/2007 - 06:37
Brandon,
could you let me know how to back up the CUE?
regards,
Anil
