Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927429members
1240135discussions
Community Activity
Cisco Packet Tracer 2960-24TT indicates Orange (amber)
Hello everyone. I work in Cisco Packet Tracer and have a simple network with 5 subnetworks connected through 2960-24TT Switch. The problem is when i connect 5 subnetworks to 1 network some (3) routes light orange (amber). And i can`t fix it. Where sh...
Puzzling results when pasting in ACL config to switch
Hello, I was creating 2 decently large ACL's to match some traffic today and I noticed something peculiar that has me puzzled. My first ACL has approx 90 ace's and pastes them fine. When I go back and look at the ACL, it looks like there are only lik...
QOS on Catalyst 9300,not showing captured packets.
Have applied the below policy map in OUT direction but I couldn't see the packets count increased but instead the total bytes output get increases. At the same time policy towards ingress which captures the match protocols increases.Input policy-For ...
VRRP issue
Facing issue with VRRP, when upstream router5 initiate traffic for downstream router6 then return traffic is not following VRRP VIP as Gateway. In my case switch2 is master and switch3 is standby.If Router6 initiate the traffic then VRRP working fine...
IOS-XE: MP-BGP における ipv4 over ipv6 の設定について
MP-BGP( Multi Protocol BGP )では IPv4 以外に IPv6 もネイバーの確立に使用できるように拡張しており、ipv4 over ipv6 設定もできます。     R1#show run interface Loopback0 ip address 1.1.1.1 255.255.255.255 ipv6 address 2000::1/128!interface GigabitEthernet0/0/0 ip address 10.1.1.1 255.25...
hongwli3 by Cisco Employee
  • 0 Views
  • 0 replies
QOS for a Destination-ip in Cisco IOSXE
Hi All,We have a URL which resolves to particular public ip and performance of that website is slow than expected from our office . We have a P2P link from office to DataCentre and from DataCentre it exits to internet. We observed the performance was...
CESアップグレードについて
はじめに一斉アップグレードの抑止リクエストアップグレード日程調整のリクエスト   はじめに 新しいバージョンのAsyncOSがリリースされてから一定期間が経過するとCESが自動的にアップグレードされます。このアップグレードは一斉アップグレード(mass upgrade)といいます。アップグレードの予定時間はCESステータスページ( https://status.ces.cisco.com/ )にて確認できます。記載された時間よりあとにアップグレードをご希望の場合は、事前にTACにご連絡ください。...
kaixzhou by Cisco Employee
  • 38 Views
  • 0 replies
Webex Calling - Webex モバイルアプリの同時通話数の制限
2024 年 4 月 19 日 (初版) TAC SR Collection主な問題 Webex モバイルアプリ(iOS,Android)で通話中に同時に複数の着信が入った場合、3 コール目の新規着信通知が出ず不在着信履歴のみ残るという事象が報告されています。 原因 Webex モバイルアプリの同時通話数の制限となります。モバイル端末の UI の制限により、クライアントがサポートする Active Call は 2 つまでとなっています。そのため通話中の呼を含め 2 つの呼がアクティブな状...
Webex Calling - サイレント モニタリングを実施した際につながらずビジートーンが聞こえる
2024 年 4 月 19 日 (初版) TAC SR Collection主な問題 スーパーバイザーが通話中のエージェント (コール キューの機能にて管理対象として割り当てられているユーザー) に、サイレント モニタリングを実施した際につながらずビジートーンが聞こえる場合があります。 原因 対象の通話がコール キューへの着信呼ではなく、エージェントのユーザー番号への直接の着信の場合、スーパーバイザーの機能(サイレント モニタリング、コーチング、割り込み、引き継ぎ)を使用することはできませ...
CUC で Ungraceful Shutdown detected が表示される
2024 年 4 月 19 日 (初版) TAC SR Collection主な問題 Cisco Unity Connection (以下 CUC) の CLI/GUI にログインする際、"WARNING: Ungraceful shutdown detected" というメッセージが表示され、CUC の再構築が推奨されています。メッセージ例: WARNING: Ungraceful shutdown detected - A rebuild of this node is highly ...
Unified CM / CUC にて Tomcat 関連のサービスが起動できない
2024 年 4 月 19 日 (初版) TAC SR Collection主な問題 Cisco Unified Communication Manager (以下 Unified CM) および Cisco Unity Connection (以下 CUC) にて、 一部のサービスが起動できないことがあります。起動できないサービスは以下のとおりです。Unified CM のサービス・ Cisco UDS Tomcat・ Cisco SSOSP Tomcat・ Cisco AXL Tomc...
