live capture? or capture on specific ip? Pix 7.0(1)
Mar 5th, 2007
The only way I've found to get info on a specific ip is by capturing the interface and doing a | include.
Without setting up an entirely new Access list is there any way to dump a specific ip adress?
Richard Burts Mon, 03/05/2007 - 14:35
Brandon
If you create a separate access list specific to the address you are interested in, then capturing that specific address is easy. But if you exclude that possibility of a separate access list then I am not aware of a good way to do it other than your solution of capture the entire interface and use include.
Rick
