Router suggestion for bonded T1
Mar 5th, 2007
I have a quick question what would you suggestion on a router. I want to run a bonded T1 but not sure what type of router I should get. I thought a 2800 series router would do the trick but I was told no. Basically it is going to be a 3 meg pipe
wgranada1 Mon, 03/05/2007 - 21:52
How did you find that? I was looking at the 2851 but didn't see where it said that it can handle a bonded T1 connection.
oyama.hall Tue, 03/06/2007 - 09:17
I've done it before. You can configure Multilink Frame Relay to bundle the circuits.
See the link below:
http://www.cisco.com/en/US/partner/products/ps5855/products_qanda_item0900aecd8033e8f9.shtml
Also:
http://www.cisco.com/en/US/partner/products/ps5882/index.html
-The Cisco 2851 Integrated Services Router provides the following support:
Wire-speed performance for concurrent services such as security and voice , and advanced services to multiple T1/E1/xDSL WAN rates
