all normal normal Cisco switches support 4094 VLANS ... depending on IOS version ...
If you set up an 802.1x TRUNK you can even trunk this 4000 VLANs
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
Jon Marshall Mon, 03/05/2007 - 23:56
Yes a 6500 will support up to 4094 vlans. You will need to have the following command (IOS) in your config
Jon
