fwsm, pdm and context config
Mar 5th, 2007
I am in the process restoring a previous multiple context fwsm to another, separate fwsm.
I copied all the contexts to a tftp server and restored one context to the new fwsm per the copy tftp:// command.
Everthing looks great from the CLI in that I can ping outbound, I can see the rule set and config settings (sh run), etc. From the context, the config looks like the old fwsm on the new fwsm.
The problem is I cannot see ANYTHING when I log into the PDM. Nothing in the Access Rules tab nor the Hosts/Network tab. The "view unknown hosts/network groups" button is disabled.
I believe I done everything from the documentation but nothing shows up in the PDM.
I am running:
FWSM Firewall Version 2.3(4) <context>
FWSM Device Manager Version 4.1(4)
Any ideas on how to get the configuration to show up in PDM?
thanks.
IWAN HOOGENDOORN Mon, 03/05/2007 - 21:48
  • Bronze, 100 points or more
Have you turned on logging?
Do a #show logging
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
