Multiple dsl connections in Single Router
Answered Question
Mar 5th, 2007
I am trying to terminate two dls connections to the same provider in a single router. I have two HWIC interfaces in the Router. The router is a Cisco 1841 series.
When the dsl line is connected to Slot 0, router is connects without issue. When I connect to the HWIC is Slot 1, the dsl continues to terminate in on Dialer 1 which is bound to the HWIC in Slot 0.
The following is a snip of the config:
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
pvc 8/35
pppoe-client dial-pool-number 3
interface Dialer1
ip address negotiated
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer remote-name isp-1-instance1
dialer-group 1
ppp authentication chap callin
ppp chap hostname isp-name-here-1
ppp chap password 7 1234567
interface Dialer2
encapsulation ppp
no ip mroute-cache
dialer pool 3
dialer remote-name isp-1-instance2
dialer-group 3
ppp chap hostname isp-name-here-2
ppp chap password 2345678
If anyone has any suggestions as it relates to the above, I would really welcome suggestions.
Ger.
Correct Answer by Danilo Dy about 10 years 4 months ago
I think the problem is in your "interface ATM0/1/0" which you have the line "pppoe-client dial-pool-number 3 " but you don't have the specific dialer interface which should be "interface Dialer3" when it can't find it, it uses "interface Dialer1". Try changing "pppoe-client dial-pool-number 3" to "pppoe-client dial-pool-number 2" in "interface ATM0/1/0"
Overall Rating: 5 (1 ratings)
Correct Answer
Danilo Dy Tue, 03/06/2007 - 04:51
  • Blue, 1500 points or more
gerard.oconnor Sun, 03/11/2007 - 16:15
That worked perfectly. Many Thanks for your Help,
Gerard.
