Tail End Hopoff
Answered Question
Mar 5th, 2007
  • Bronze, 100 points or more
Does anyone know where I can find a basic (and preferably free) listing of which area codes are local to which other area codes? We're looking at tail-end hopoff and I can't find a good listing of which area codes besides the explicit ones to route out remote gateways (for example, I know a call to 913 from Nevada should be routed out the Kansas City router, but 816 is also local and should also be sent out the KC router).
Jim
Correct Answer by lfulgenzi about 10 years 3 months ago
This is what I use:
http://www.localcallingguide.com/
For you, I would go to:
http://www.localcallingguide.com/lprefix.php?exch=064370&dir=1
That has all local calling for Kansas City, KS.
Lelio
Overall Rating: 5 (1 ratings)
astinus Mon, 03/05/2007 - 14:21
Outstanding, thank you very much for the quick response, this appears to be exactly what I need.
Jim
lfulgenzi Mon, 03/05/2007 - 15:49
  • Silver, 250 points or more
No problem, hope it helps.
