ACE probes for database
Answered Question
Mar 5th, 2007
I am trying to check the database status using ACE probes.
I am only able to check status of listner (port status).
Is there any way to check the status of database using ACE probes.
Thanks in advance
Aniruddha
Correct Answer by Syed Iftekhar Ahmed about 10 years 4 months ago
One way of doing it would be to use a webserver to construct a page by fetching some data from DataBase server.
Use TCl to check for the data value on the page.
Overall Rating: 3 (1 ratings)
ab_parkhi Mon, 03/05/2007 - 21:06
ACE does not support packages(sql) ,i will not be able to check database status.
Is there any way to check database status using plain TCL?
Correct Answer
Syed Iftekhar Ahmed Mon, 03/05/2007 - 22:44
  • Blue, 1500 points or more
