C2800 Series with Integrated Switch
Mar 5th, 2007
I have a C2821 with a Switchcard - I wantto get the vlans working. I am used to C6000 Series, however this model does not allow for set commands etc I have tried to get VTP flowing between them - the card is known as GI1/0.
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1/0
no ip address
interface GigabitEthernet1/0.1
no ip address
encapsulation dot1Q 1 native
ip address 10.1.1.254 255.255.255.0
no snmp trap link-status
interface GigabitEthernet1/0.2
encapsulation dot1Q 2
ip address 10.2.1.254 255.255.255.0
ip classless
no ip http server
Show VTP Counters shows this:
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
R-CORE-1#show vtp coun
VTP statistics:
Summary advertisements received : 0
Subset advertisements received : 0
Request advertisements received : 0
Summary advertisements transmitted : 0
Subset advertisements transmitted : 0
Request advertisements transmitted : 0
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
R-CORE-1#
I have created a databse on the router but its not propergatting to the switchcard or a seperate switch ? What have I done wrong - I can't seem to use trunk commands on this but reading a cisco tech thing the above should work !?!?
I have added a switch plugging into the integrated switch and these are communicating fine:
VTP statistics:
Summary advertisements received : 3
Subset advertisements received : 1
Summary advertisements transmitted : 3
Subset advertisements transmitted : 1
Request advertisements transmitted : 11
Gi1/0/2 0 0 0
Fa1/0/16 0 0 0
Do you create the vlans on the integrated switch instead and ifso does this mean the router won be routing them ???
Thanks for any help
Ed
edw Tue, 03/06/2007 - 02:53
I know that ;) I created a vlan database on the router but the problem is it isnt propergating to the integrated switch ??
Ed
