Frame Relay to MPLS
Mar 5th, 2007
We currently have a Frame relay Network comprised of 80 plus sites running EIGRP. We will be migrating to an MPLS network soon using Juniper Routers. Are there any recommendations on how best to accomplish this??? Any help would be greatly appreciated.
iwan@i-lusion.nl Mon, 03/05/2007 - 21:43
For handy commands for Juniper/Cisco look here:
http://networking.ringofsaturn.com/Cisco/ciscojuniper.php
Cisco can work well in a mixed vendor enviroment and so can juniper ... the think is that you need to do some propper testing ...
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
mdumont71469 Tue, 03/06/2007 - 05:45
Since the MPLS network will be using BGP would it be better to enable OSPF on the Cisco Frame routers along side EIGRP and then do some redistribution or would it be better to use static routes?? Is there a best practice design for this scenerio???
