Admin access scenario
Mar 5th, 2007
Guys,
what's the best way to deploy the below-mentioned setup
What's setup on tacacs
-NDGs containing list of AAA devices classfied by country.
I have an administrator that needs to access only 3 of the NDG and be denied access to the rest.
Do i achieve this with
-New group setup restricting TACACS+ and Enable Options to just the 3 NDGs?
-create this new administrator and have him assgined to this new group
Also,am i able to do the following :
-make a user be part of several Groups
-allow a user acces to 1 NDG and several standalone AAA clients that are not part of a group.
Overall Rating: 3.3 (3 ratings)
darpotter Tue, 03/06/2007 - 04:18
  • Silver, 250 points or more
You have a couple of choices. If this admin belongs to a group and they have similar profiles you could create a group with an IP based NAR allowing access to only the named NDGs.
or, if its a special case you can assign NARs directly to the admin user in question.
User cannot be in several groups. However using NDG->NAR and NDG->DCS mappings you can make users of a group get different authorisations based on the devices being managed, eg NDG1->full access, NDG2->read only
NARs can contain NDGs, NAFs and individual devices.
Darran
echelon360 Thu, 03/08/2007 - 00:23
Thanks for the notes on this.
I've created two Shell Command authorization Set
-Full Rights
-Read Only
I've assigned a user access to specific NDG with full rights.When i use his credentials to log into another switch that is not part of his NDG allow list,i'm puzzled.
Now i can't get into enable mode (that's the intended purpose) but i can run show ip/trace/ping w/o going to enable mode. It seems that this user has been assigned the Read-only shell command authorization set for all other switches.
Is there a way i can stop this?
darpotter Thu, 03/08/2007 - 04:03
Hmm, interesting in theory the default position should always be to deny.
Anyway you could force this. Create a new empty DCS with default cmd = deny.
Add an entry at the bottom of the NDG->DCS mapping table using the special entry, ie --> DENYALL.
If that doesnt fix it... then, um.. I'll eat my hat!
echelon360 Thu, 03/08/2007 - 04:23
Thanks but i have just one qtn, i'm using the Cisco ACS Appliance(CSACSE-1113-K9). correct me if i'm wrong but is DCS available on that?
darpotter Thu, 03/08/2007 - 07:17
Yes, DCSs are available. You might have to switch them on in interface config.
