Timestamps not displayed with debugs
Answered Question
Mar 5th, 2007
Hi All,
At the moment I am still studying so please forgive this probably obvious issue!
I have the clock set which I have verified with the show clock command. This displays correctly with the correct time, date etc.
However when I issue debug commands I get the uptime? values, ie 3d06hr.
What is it that I am missing here for the debugs to display the actual set time?
If it matters the router is a 2500 running 12.2(7r)XM1 as the IOS.
Correct Answer by spremkumar about 9 years 11 months ago
hi
can you also try this command under your router config ?
service timestamps debug datetime msec localtime show-timezone
But make sure that you hve proper clock time set on your router to have proper time getting displayed ...
regds
Overall Rating: 5 (2 ratings)
spremkumar Mon, 03/05/2007 - 22:07
Can you post out the config which you have done it out there in your router over there ?
regds
Correct Answer
spremkumar Mon, 03/05/2007 - 22:14
hi
regds
Danilo Dy Mon, 03/05/2007 - 22:16
Try putting these two lines in your config
service timestamps log datetime msec localtime show-timezone
