need info about "sh int dot11Radio" and "sh int dot11Radio stati"
Mar 5th, 2007
Could someone explain me the counters in the 2 following display on an AP (like a AIR-AP1231G)
sh int dot11Radio 0
sh int dot11Radio 0 statistics
SiteR02#sh int dot11Radio 0
Dot11Radio0 is up, line protocol is up
Hardware is 802.11G Radio, address is 000f.3415.bf30 (bia 000f.3415.bf30)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Last input 00:00:12, output 00:00:12, output hang never
Queueing strategy: fifo
Output queue: 0/30 (size/max)
24680 packets input, 3282575 bytes, 0 no buffer
Received 129 broadcasts, 0 runts, 0 giants, 0 throttles
23427 packets output, 4831674 bytes, 0 underruns
212 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
SiteR02#sh int dot11Radio 0 statistics
DOT11 Statistics (Cumulative Total/Last 5 Seconds):
RECEIVER TRANSMITTER
Host Rx Bytes: 3265473 / 0 Host Tx Bytes: 4338004 / 0
Unicasts Rx: 88699 / 1 Unicasts Tx: 27040 / 0
Unicasts to host: 88699 / 1 Unicasts by host: 23629 / 0
Broadcasts Rx: 0 / 0 Broadcasts Tx: 4601528 / 49
Beacons Rx: 0 / 0 Beacons Tx: 4601528 / 49
Broadcasts to host: 0 / 0 Broadcasts by host: 0 / 0
Multicasts Rx: 0 / 0 Multicasts Tx: 0 / 0
Multicasts to host: 0 / 0 Multicasts by host: 0 / 0
Mgmt Packets Rx: 0 / 0 Mgmt Packets Tx: 3411 / 0
RTS received: 0 / 0 RTS transmitted: 1721 / 0
Duplicate frames: 230 / 0 CTS not received: 1597 / 0
CRC errors: 4303 / 0 Unicast Fragments Tx: 26833 / 0
WEP errors: 0 / 0 Retries: 2540 / 0
Buffer full: 0 / 0 Packets one retry: 435 / 0
Host buffer full: 0 / 0 Packets > 1 retry: 174 / 0
Header CRC errors: 43265 / 0 Protocol defers: 2 / 0
Invalid header: 311 / 0 Energy detect defers: 206 / 0
Length invalid: 0 / 0 Jammer detected: 0 / 0
Incomplete fragments: 0 / 0 Packets aged: 0 / 0
Rx Concats: 0 / 0 Tx Concats: 0 / 0
RATE 2.0 Mbps
RATE 5.5 Mbps
RATE 11.0 Mbps
SiteR02#
Somes counters are displayed on those 2 displays but it is not with the same figure (CRC errors, input, output, broadcast, ...)
Can someone explaines me this ?
regards,
hadbou Fri, 03/09/2007 - 13:46
Show interface statistics shows number of error free packets whereas show interface statistics shows total number of packets.
jabouaf Mon, 03/26/2007 - 08:38
Hello, do you know the formula ?
If I had errors to the "input field -from sh int-" then I don't get the unicats received field in the "sh int stat".
