TACACS configuration in Cisco 6509
Answered Question
Mar 6th, 2007
i wanted an equivalent command for configuring in Cisco 6509 running Cat OS.
i know Catalyst OS to Cisco IOS configuration converter is there, but i am looking for Cisco IOS to Catalyst OS configuration converter? can any one help me in this regard.
looking for a equal command for the following
aaa new-model
aaa authentication login default group tacacs+ enable local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host 10.203.1.92 key checkingtheswitch.
since it is a Cisco 6509 production switch, i don't want to take chance, as there is a possibility that i might not login if the configuration is incorrect.because i faced similar situation when i implemented in Cisco IOS in the initial stage in one of the edge switch.later i have reset the switch & finally could implement with the working config as mentioned above.
Correct Answer by Amit Singh about 9 years 10 months ago
Hi Anand,
Please use the link below for more info.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/confg_gd/authent.htm
-amit singh
Overall Rating: 4 (1 ratings)
Anand Narayana Tue, 03/06/2007 - 01:40
Thanks Amit,
This document was very useful contains more informations about AAA than what i was looking in for.
jwhitepnv Tue, 10/16/2007 - 06:50
did you ever get an answer on the config? I have a 6500 setup but enable does not work correctly
Jagdeep Gambhir Tue, 10/16/2007 - 09:20
What exactly is happening. Here are the cat os commands for aaa,
onsole> (enable) set tacacs server [IP] [primary]
set tacacs key [key]
set tacacs attempts [number] (optional)
set localuser user [user] password [password] privilege 15
set authentication login local enable
set authentication login tacacs enable [all | console | http | telnet] [primary]
set authorization exec enable tacacs+ [deny | none] [console | telnet | both]
set authorization commands enable [config | all] tacacs+ [deny | none] [console |
telnet | both]
~JG
Please rate helpful posts
