acs 1113 prb
Mar 6th, 2007
dear all,
i ve a new 1113 box and according to the manuals i configured the passwords.after that when i checked it using console its showing windows booting and all and after that no change at's not taking any passwords and i cant do anything in that can anybody suggest whats the next step.
i will rate all the posts.
echelon360 Thu, 03/08/2007 - 06:16
Sounds a lil like how i started out.
To console into the appliance, make sure you use the provided cables and ensure baud rate is set at 115200.
Once your in, you should be able to login using the password u have set earlier on. Configure the ip settings accordingly therafter.
From there, launch the web browser and enter
http://ip address:2002
You should be able to take it from there :)
