Outbound, callresult 13 and 16
Mar 6th, 2007
Hi!
Question about Cisco Outbound Option (7.0):
What callresult=13 means? Is it
a) dialer cancelled a ringing call
b) error code, if so, what it means?
c) normal callresult?
What's callresult=16? Is it code which appears when dialer abandons call because there is not enough free agents, in progressive or predictive mode?
So when I set abandon calls limit to 2% in Cisco Configuration manager, system monitors callresults 16?
It's strange that we still got callresult=13 even when the settings are:
-lines per agent = 1.0
-maximun lines per agent=1.0
Is it possible that Cisco dialer makes nuisance calls even in progressive mode with those parameters? So that customer receives very short call (1-2 seconds) which dialer cancels because some unknown errors????
jaska_jokunen Mon, 03/12/2007 - 05:45
So I guess this result 13 is normal callresult?
Any Cisco professionals here, maybe from development team?
jaska_jokunen Tue, 03/13/2007 - 02:10
Same time when system has called to phone number 091234567 and got CallResult=13 to Dialing_List tables, there is CallDisposition=26, PeripheralCallType=7 for that phone number in Termination_Call_Details -table.
According documentation CallDisposition=26 means "U-Abort, Not currently used"
Uhm, what's this? U-Abort?
jaska_jokunen Fri, 03/16/2007 - 04:37
Seems to be "In Outbound Option: this result code indicates the outbound call was stopped before the customer picked up"
But I would like to know is this normal result code.
Gergely Szabo Fri, 03/16/2007 - 16:26
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
if tcd.CallDisposition = 13 AND the call is ICM routed, this means the OO agent handled the call "ab ovo usque ad mala" - this is what you are probably looking for.
