Priotry QoS on My multiple traffic
Mar 6th, 2007
I am hving P2P connectivity between my head office and remote office with 128 kbps link.
they are access database server & lotus notes mail server .
They r facing issue facing data base server .
I have found my mail traffice is using most of the bandwidth.
I like to apply PQ on the basis of ACESS LIST .
mY FOUR DATA BASE SERVER IS
10.10.10.1
10.10.10.2
10.10.10.3
10.10.10.4
i LIKE TO GIVE HIGH Priority to this traffic
Can any body advice how i can achive.
Can u tell me on which site i hve to applied this Priority List.
Anonymous (not verified) Tue, 03/06/2007 - 02:50
First create an access list:
access-list 10 permit 10.10.10.1
access-list 10 permit 10.10.10.2
access-list 10 permit 10.10.10.3
access-list 10 permit 10.10.10.4
Then create a priority list linked to the access list:
priority-list 1 protocol ip high list 10
priority-list 1 default low
then assign priority-group 1 to your external interface.
Hope this helps
jitendra_pipalia Tue, 03/06/2007 - 08:54
hi
Actully I have created access list as below
access list 101 permit ip any host 10.10.10.1
access list 101 permit ip any host 10.10.10.2
access list 101 permit ip any host 10.10.10.3
access list 101 permit ip any host 10.10.10.4
Will be right ?
and I have applied this priority list to serail interface of my remote router.
Can u tell me i hve to applied on both the router?
One which is in my head office and other in my remote office.
mY Main concern that my remote site users should get this server application faster.
Anonymous (not verified) Tue, 03/06/2007 - 23:51
Its best to stick with a standard access list, not an extended one.
Yes you should apply it to both routers.
jitendra_pipalia Wed, 03/07/2007 - 09:59
hi
thnaks for the information.
But today it was same issue .no much improvement on performance.
Any other way of queuing method to resolve issue ?
csco10387876 Thu, 03/08/2007 - 02:12
I think the best solution would be if applicable :
you should apply classification and marking of your mail traffic on both user port and server port with a priority of AF31 or CS3
then on both side of your wan link you should apply LLQ (CBWFQ+PQ) with a class for mail and for this class in your policy map use priority percent.
if you look on the cisco website you should find some sample config.
Luc
hope it helps
mheusinger Thu, 03/08/2007 - 02:35
  • Green, 3000 points or more
First, are you sure your ACL on BOTH sides describe the traffic correctly? As the traffic direction is different you need to exchange source and destination on one of your routers. Do you get matches (show ip access-list)?
Second, there are better queueing methods (depending on your IOS version), like CBWFQ.
If you like, then try CBWFQ, which could look like this in your case:
Server side router
ip cef
class-map match-all Mail
match ip address 100
policy-map Mypolicy
class Mail
bandwidth percent 50 !adjust to your needs up to 75%
class class-default
fair-queue
random-detect
interface Serial0/0
description line to your branch office
bandwidth 128
ip address 10.0.0.1 255.255.255.252
no fair-queue
service-policy output Mypolicy
access-list 100 permit ip host 10.10.10.1 any
access-list 100 permit ip host 10.10.10.2 any
access-list 100 permit ip host 10.10.10.3 any
access-list 100 permit ip host 10.10.10.4 any
Branch office router:
ip cef
match ip address 101
policy-map Mypolicy
class Mail
class class-default
fair-queue
random-detect
interface Serial0/0
description line to head office
bandwidth 128
ip address 10.0.0.2 255.255.255.252
no fair-queue
access-list 101 permit ip any host 10.10.10.1
access-list 101 permit ip any host 10.10.10.2
access-list 101 permit ip any host 10.10.10.3
access-list 101 permit ip any host 10.10.10.4
You need to adjust interface namings, IP addresses and the like to your envitonment.
I would also advise you to read f.e. "Enterprise QoS Solution Reference Network Design Guide Version 3.3" and especially the section about brach office QoS.
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Finally: QoS does NOT create bandwidth! So if your line is too small for the traffic you have, only a line upgrade can help. QoS just sorts out, which traffic gets the little bandwidth available. 128k maybe not enough, taking into account emails with tens of MB attachements.
Hope this helps! Please use the rating system.
Regards, Martin
