Jon Marshall Tue, 03/06/2007 - 03:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Do you have a Cisco login. if not you need to register a Cisco account. Go to this page and register
https://tools.cisco.com/SWIFT/Licensing/RegistrationServlet
Once you have a login go to
www.cisco.com/go/license
You will be prompted for you username/password.
Once on this page in the box at the top labelled "Licenses not requiring a PAK" click on the "here for available licenses" link.
Then scroll down to select the 3DES pix firewall license and follow the instructions. You will then be e-mailed with your 3DES update key.
suschoud Tue, 03/06/2007 - 07:45
  • Gold, 750 points or more
hi,
you can get 3des license free.However,for AES,you'll have to purchase an additional license.
you can get the 3des by following the instructions in the above message.
the new activation key which is mailed to you can be entered by this command :
activation-key < four tuple key >
Hope this helps!!
Sushil
TAC Engineer
