Basic questions about adding IPSEC clients to IOS firewall
Mar 6th, 2007
I have an IOS firewall (2811 router) with WebVPN and SSL VPN clients already in use. This works OK, but my Macintosh computers don't work with SSL VPN so I was looking at adding IPSEC clients to the same firewall for the MACs.
1. Question 1 - will this work ?
2. Question 2 - How would this be configured. Do I have to set up a different gateway on the router using a different external IP than my WebVPN and SSL VPN gateways ?
Thanks for any input. I am new to configuring these boxes.
kaachary Tue, 03/06/2007 - 06:39
1: This will work.
2: No, you can use the same public interface for terminating IPSec connections.
Check this doc for MAC client config :
And this doc for Router's config for IPSec :
Hope this helps.
