SSID broadcast
Mar 6th, 2007
Hi, I need to stop broadcasting my ssid as its being reported that in our office if a Wi-Fi scan was done with any handheld device our ssid is visible on it. The requirement is to stop that. Can you please suggest me how can i do that on a Cisco 1200 Series access point?
Amit Singh Tue, 03/06/2007 - 05:49
Using GUI for the AP,You can disable SSID from broadcasting.If you go to the SSID Manager page, there will be a selection for "Guest Mode" which is probably checked. Just un-check "Guest Mode" and this will stop the SSID from being broadcasted.
-amit singh
proteksa2006 Tue, 03/06/2007 - 09:33
you could access via CLI and post the show running?
you have to disable "guest mode" on the ssid.
thanks
palukuri77 Tue, 03/06/2007 - 10:18
Hi, Its not enabled. I can paste you the configuration.
version 12.3
no service pad
service password-encryption
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip domain name www.corp.teradyne.com
aaa new-model
aaa authentication login default local
aaa session-id common
dot11 ssid [email protected]
authentication open
dot11 network-map
crypto pki trustpoint TP-self-signed-699185896
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-699185896
revocation-check none
rsakeypair TP-self-signed-699185896
crypto ca certificate chain TP-self-signed-699185896
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 36393931 38353839 36301E17 0D303230 33303130 30303830
335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3639 39313835
38393630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
BC707969 1FFAC525 7C809C98 D084BD1C A7C4D79F 97866F37 C0F74B5C 64DD5AF5
8034D925 088DD884 0FEBFC0D E23D8E16 098E5ADC C8994208 CA3EF5D7 8C4CB77B
9D8D3280 59F207F0 FC7BE2B5 8DFAFAC0 2BCC2873 7655392E B5F2C285 0269DF85
993AA24D F56DC1A7 C9F6622A 46DB7E19 2A73EEBF 2BE7F465 7487AF20 63D8F853
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 1680141D 00F50257 12ED57F4 3CD13B71 F58FD194 CEB96130 1D060355
1D0E0416 04141D00 F5025712 ED57F43C D13B71F5 8FD194CE B961300D 06092A86
4886F70D 01010405 00038181 004A2A2C 03CCA967 CF943159 39C92787 2668950A
AD9EA7DA 2DA591C2 705AF4CE 5565B77C 84E76C72 FF24BB1F 3F1C7380 4B490675
FBBAA57D 0C45CFD0 B5A2E760 02A9CFDF 5D5D3641 30D451FA FBCD3CC8 2803D439
97B03620 161398F7 AB74A916 BC01682C 84276AF1 AD0156BE 75A048ED 6A559CE1
F219CB0E F6A738F5 64B3CB7E DB
quit
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 2 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxx transmit-key
encryption mode ciphers tkip wep128
speed basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0
basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2437
station-role root
rts threshold 2312
l2-filter block-arp
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 131.101.179.222 255.255.255.0
no ip route-cache
ip default-gateway 131.101.179.254
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/ea0
ip radius source-interface BVI1
control-plane
bridge 1 route ip
line con 0
line vty 0 4
line vty 5 15
sntp server 131.101.17.251
end
This is the sample configuration. We have recently shipped 6 access points with this type of configuration to one of our offices in Asia and they complain that with these access-points the ssid is visible if they scan with any Wi-Fi device and with the previous existing access-points in the office its not visible. We compared the configuration to be same for all access points. Any idea whats the problem???
