How to replace an AP on the WCS map
Mar 6th, 2007
I have an out of service AP 1131. I have a replacement ready to install but I'm concerned w/ the map on the WCS. How can I go about replacing the existing AP w/ the new AP while using the existing name?
Robert Maldonado
Sr. Systems Administrator
erik.estrada Tue, 03/06/2007 - 09:15
Robert,
After installing the new AP and get it sync'd up with the controller.Rename the new AP. Then simply delete the first one from the map and add the newly installed AP to the map.
Shouldn't be to bad at all.
robmaldowsusom Tue, 03/06/2007 - 10:45
Erik,
While it wasn't as easy as I would have hoped deleting the existing one prior to adding the one one worked out fine.
Thanks for your suggestion.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
