DST Change Workaround on Unity and Call Manager
Answered Question
Mar 6th, 2007
We have 2 CCMs v4.1(3)es24, and 1 Unity 4.0 Build 4.0 (2).
Instead of installing the DST patches made available by Cisco, we are going the workaround path - by changing time manually on the CCM and Unity.
I know time on publishers should be changed before time on subscribers machines are changed, but I m unsure where Unity fits in.
Do I have to change time manually on Unity after changes on CCMs are done or should it be done prior to changing time in CCMs.
I did searched on cisco.com but couldn't find the answer I was looking for.
Correct Answer by rob.huffman about 9 years 10 months ago
Hi Mirza,
As there is little or no correlation between the two system clocks in Unity and CCM, I think you could do these changes in either order. If it were me, I would do the Unity workaround first as the need for the correct time is probably more important in VM Time Stamps etc.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Tue, 03/06/2007 - 07:24
Hi Mirza,
Hope this helps!
Rob
ddunk0077 Tue, 03/06/2007 - 11:33
I was reading this forum as well. Can the workaround as far as manually changing the time work for Unity servers that are running
4.0(4)
mzsaad123 Wed, 03/07/2007 - 07:32
Another query that I have regarding DST workaround is that on a running Publisher, SQL is running and other services. Also antiviruses are installed, do I need to disbale anything like that before I do the manual time change. Likewise on Unity.
I tried to look this up without much success on cisco.com.
Thanks.
rob.huffman Wed, 03/07/2007 - 07:56
Hi Mirza,
I'm not sure about Unity (haven't tried) but on CCM you shouldn't need to stop any services or disable Antivirus;
CCM OS Manual Workaround 3.x and 4.x
On the new US DST date, Logon with sufficient privileges to CCM Windows Server (starting with Publisher)
Click Start, Settings, Control Panel, Date and Time
Adjust the time accordingly
Click on TimeZone tab
Uncheck the Automatically adjust clock for daylight savings changes
Click Apply or Ok
Repeat steps for all servers in the cluster.
When DST ends in the Fall, the clock would have to be manually adjusted again using the same method described in steps 1-3 and 6-7 above. Please note, however, that manually adjusting the clock on CCM servers could result in a conflict in time which may produce time synchronization issues.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a00807e02b1.shtml
Hope this helps!
Rob
mzsaad123 Wed, 03/07/2007 - 08:18
Thanks for the reply Rob.
Yes your reply helped. However I am unable to find simiar page for Unity. Here is what I found:
Workaround:
If the patches to Windows and Unity are not applied, time may be adjusted manually through the Windows Operating System.
Ref: http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_field_notice09186a00807dcf40.shtml
No information from Cisco means it won't affect. And I donot need to disable services and stuff.
