CM5.x - IP Communicator DLU
7aelahi
I'm looking around to see how many DLU's (Device License Unit) an IP Communicator requires. I found this page but it doesn't mention anything about IP Communicator.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtml
Rob Huffman
Hi Ali,
Just to add a note to Stephanies excellent info that IP Communicator requires 3 DLU. Here is a good reference doc (look on Page 4)
http://www.cisco.com/warp/public/765/tools/quickreference/ipphones.pdf
Hope this helps!
Rob
srichardson
Level 4
Level 4
There used to be a pdf document on CCO but since Cisco modified their search engine, not all results are coming up. The IP Communicator is 3 units. The only reference to prove this to you I can find is now on steps to success. Do a search for "CallManager Licensing" and a .ppt will come up.
Trying to provide you the link:
http://tools.cisco.com/s2slv2/search.do?method=doBasicSearch&modulename=Search&CategoryName=S2S%20Content&SearchText=callmanager%20device%20license
Rob Huffman
Hi Ali,
Hope this helps!
Rob
