unable to ping public address behind pix
Answered Question
Mar 6th, 2007
Hi all,
i am using pix 7.0. I have opened any any access for my users behind the fw, bt none is able to ping public addresses like www.yahoo.com or ip 66.45.172.7.
pls see attached show run
Correct Answer by vitripat about 10 years 2 months ago
Perhaps, you dont even need to use access-lists. With 7.0 code PIX can do stateful inspection of ICMP and track the replies coming from outside and allow them if they match the requests initiated from the inside network. To do so, you can implement following commands-
policy-map global_policy
class inspection_default
inspect icmp
inspect icmp error
exit
exit
Now check if you are able to ping outbound.
Vibhor.
Correct Answer by suschoud about 10 years 2 months ago
please add the command :
access-list acl-internet extended permit icmp any any
this is the access-list on outside interface.when you try to ping anything on internet,the icmp echo request reaches that ip address,an icmp echo response is generated which reaches the firewall's outside interface.
as the access-list on outside interface do not permit the icmp,they'll be dropped and that's why u do not get replies on the inside.
there's are many icmp commands which you could permit individually.
for details,please check:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
Hope this helps!!
Sushil
Cisco TAC.
Overall Rating: 4.8 (3 ratings)
Correct Answer
suschoud Tue, 03/06/2007 - 07:41
  • Gold, 750 points or more
Hope this helps!!
Sushil
Cisco TAC.
Correct Answer
vitripat Tue, 03/06/2007 - 08:06
inspect icmp
inspect icmp error
exit
exit
Vibhor.
vince-tran Tue, 03/06/2007 - 11:41
permit icmp any any echo-reply from internet( acl-internet)
and permit icmp any any echo from inside (acl-inside)
That should do it.
