Wireless connection between MAR3200 and WLC2006
Mar 6th, 2007
The goal of our application is a data transmission network between the ground infrastructure and vehicles. On the ground, we planned to use LWAPP AP1242 managed by a WLC. On board, we planed to use a MAR3200, fitted with 2 WMIC. In a first time, we are setting up a test bed with a WLC2006 (v4.0.206) and 5 AP1242 max (a single AP1242 is enough for a first step).
The management and AP-manager interfaces of the WLC are mapped on a single VLAN, while a dynamic interface supports the data traffic. The MAR3200 is stated "associated" by the WLC. When an IP address is assigned to the BVI interface of the WMIC, the linktest passes. Nevertheless, I can not ping the WLC management interface from the MAR3200. I guess that the configuration is bad, but which parameters are wrong or missing?
I attached the configuration of the AP, the WLC, the MAR3200 and the WMIC.
Thanks by advance for any help.
Best Regards,
Alain-Claude
Attached file: <<martec_config_070306_163000.zip>>
