Distinguishing between VM and UM subscribers
Mar 6th, 2007
Hi, All!
A customer has a Unity 4.0x box with licenses for both VM and UM subscribers, but whenever he tries to add a subscriber, it ends up in licensing as a VM subscriber, consuming all VM licenses and leaving the UM ones untouched. How does Unity distinguish between both types of subscribers? Regards,
Brandon Buffin Tue, 03/06/2007 - 08:39
This is determined by the Class of Service of the subscriber. If you go to COS in Unity web admin and click Features, you will see a radio button for Voice Messaging/Unified Messaging. So, you could create a new COS designated as Unified Messaging and use it to create UM users.
Hope this helps. If so, please rate the post.
arielroza Tue, 03/06/2007 - 10:29
There is no such setting in the Features section of the CoSes defined. This is Unity 4.0x.
Is there any other way?
To clarify... the box used to be a voicemail only server, but after that our customer bought the license upgrade from VM to UM. The UM licenses are installed, but none of them are used...
