03-06-2007 08:34 AM - edited 03-14-2019 08:20 PM
We are running CCM 4.1(3) and have four VG248 analog gateways. I've noticed in the event logs of both our CCM's Transient Connections from 2 of the 4 VG248's every two seconds. In addition on the VG248's I'm seeing "Warning: SCCP 35: Registration failed: Error: DB Config".
Everything seems to be in working order other than these errors every few seconds. The other two 248's are not generating any errors. I've restarted the two 248's with no effect.
We recently upgraded the OS on both Call Managers to 2000.4.4aSR3a if that matters.
This is the error from the event log on one of the Call Manager boxes:
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 3/6/2007
Time: 11:15:09 AM
User: N/A
Computer: IPCM1
Description:
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 0
Device name [Optional].:
Device IP address.: 10.10.0.14
Device type. [Optional]: 255
Reason Code [Optional].: 6
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Node ID: 10.10.0.5
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
Any ideas?
Thanks!
Todd
Solved! Go to Solution.
03-06-2007 08:45 AM
This happens when a port is enabled on the VG248 but is not configured on CallManager.
If you have auto enable configured, what happens is that a port will be enabled automatically, but left enabled if you delete that phone from CallManager.
Disabling the port will remove the transient connection attempts.
You should also consider going to manual enable mode.
EDIT: I believe the "SCCP 35" error points you to port 35.
03-06-2007 08:49 AM
Hi Todd,
This error usually indicates where a port on the VG has been deleted via CCM but not disabled in the VG port config via cli. The port ties to Auto-Register over and over again until you disable the port in the VG itself. In the error log look for the mac-address of the VG and the last 2 digits represent the actual port # that is causing the problems.
Access the VG via Telnet or Console Go to
Configure>Telephony>Port Specific Parameters>Port Selection (select applicable port and Disable)
This should be the end of these errors :)
Hope this helps!
Rob
EDIT: Slow typist at work!
03-06-2007 08:45 AM
03-06-2007 08:49 AM
Thanks! That was it.
Todd
03-06-2007 08:49 AM
Hi Todd,
Hope this helps!
Rob
03-06-2007 09:03 AM
BTW - We are using manual on the VG248's. What happened was an analog phone was deleted out of the Call Manager and no one bothered to tell me about it :-\
03-06-2007 10:09 AM
That never happens here. ;)
