Changing the default Codec and packet size in CME
Mar 6th, 2007
CME version 4.0(0). I need to change the default codec to G729r8 and the default packetsize to 60 bytes on all 7960 phones. Can anyone help?
thisisshanky Tue, 03/06/2007 - 09:58
  • Purple, 4500 points or more
You can change the codec type under each ephone using the codec command.
Sankar.
