7960 sip upgrade.
Mar 6th, 2007
Hello
i have some problems upgrading a 7960 sip phone , non call manager.
it was working fine with 3.7.3 version and was registerred to some sip aerver until i decided to play with it and upgrade to P003-08-6-00.bin.
i tried to follow this doc but i guess i missread something ->
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7960/addprot/mgcp/frmwrup.htm#wp1049043
i have d/l the zip file with the following:
P0S3-08-6-00.sb2
P0S3-08-6-00.loads
P003-08-6-00.sbn
P003-08-6-00.bin
OS79XX.TXT --> where i changed to P0S3-08-6-00
also , downloaded :
SIPDefault -> where i put : image_version: P0S3-08-6-00
i see on tftp that it is trying to pull the files but on the phone i see application upgrade failed.
ideas ?
thanks
okenobi Tue, 03/06/2007 - 10:44
fixed it , phones loads now..
2 more questions.
1 i can not get rid of the football extension even though i removed it from the sipMyMAC.cnf
2 i am able to register and make calls via my sip server but can not get calls.
i enabled the nat thing but nada.
paolo bevilacqua Tue, 03/06/2007 - 14:14
  • Hall of Fame,
    Founding Member
the thing that not all sip releases appears to work in non-CM. Eg if you user asterisk user report that 8.0(2)SR1 was goof but others are not.
So if you can't find a release that works, traces are needed to see why it is not receiving calls.
