IOS damage, what?s my option ?
domwilko1 Wed, 03/07/2007 - 15:59
Hi Martin,
Have you tried to reload the IOS using the Reset button and TFTP upload method?
1) Connect a crossover cable between your AP and PC/Laptop.
2) Set the PC/Laptop IP address to 10.0.0.2 255.255.255.0
3) Copy the IOS file in to the root directory of your TFTP server and rename it to c1200-k9w7-tar.default.
4) Start up the TFTP server on your PC/Laptop.
5) If not already off, then power off AP.
6) Power on AP whilst holding down the Reset button until the Red light comes on (about 20 seconds), then release the button.
7) The AP should then start loading the IOS image from the TFTP server.
If there is not enough room on the flash to hold both IOS images (new & corrupted one) then it should delete the old image first. This is done automatically.
Hope this helps,
Dom
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
