Testing DNS and WWW from ADSL router
Mar 6th, 2007
Is there a way to test DNS and WWW from the 800 series ADSL router using the BV interface as your source?
Am I right in saying that what ever I test using the BV as the source would be the same as testing it as if I had a PC on the router and the router using NAT?
Overall Rating: 5 (1 ratings)
You can test connectivity by doing:
ping x.x.x.x source BVI1
Assuming that you have a dns server set on the router, you could do the following:
ping www.google.com source BVI1 - Test DNS
telnet www.google.com 80 /source-interface BVI1 - Test WWW/DNS
The telnet will not give you much of anything, but it'll make a connection or not. You should also be able to look at your NAT translations to verify if that BVI1 ip address was properly translated.
Good luck.
bradlesliect Tue, 03/06/2007 - 12:12
I did that already when i configured the router. Was wondering if there was another way to do this.
Would the test be the same as doing it from the PC on the network?
