hoogen_82 Wed, 03/07/2007 - 23:32
  • Silver, 250 points or more
The most stable IOS for sup720 would be 12.2(18)SXB or SXD.
This also need to be checked against the release notes to ensure that the features you are using do not hit on any known bugs. 12.2.(17) was bug ridden so anything 12.2(18) should be fine.
CatOS most stable would depend on the feature set your using some of my customer are running on 8.3 though.
Go through the release notes before you take a decision.
Hoogen
Rajat Chauhan Sat, 03/10/2007 - 10:33
  • Cisco Employee,
Its a good idea to rely on SAFE Harbor Testing when it comes to suggestion for stable images on Cisco platforms. Ofcourse, you might want to check release notes once for any specific or special feature you require.
CatIOS: 8.5.7
IOS: 12.2.18 SXF6
Please see:
http://www.cisco.com/en/US/netsol/ns504/networking_solutions_program_category_home.html
Please rate as helpful.
Rajat Chauhan
