DiRT Backup cmbbackup error
Mar 6th, 2007
While performing a backup using DiRT I encountered this error in the logs...
cmbBackup Routine:Permission denied number =0
Does anyone know what that error is?
MikeTomasko Tue, 03/06/2007 - 13:38
  • Bronze, 100 points or more
What version of Unity?
Exchange or Domino?
What Version of DiRT?
What Account are you running DiRT as?
williamka Tue, 03/06/2007 - 14:47
I found this error...
CSCef52573
ciscosecurityagent
DiRT Backup failure with CSA.
Symptom: When doing a DiRT backup and CSA is running, the backup will fail with the error listed below.
8/20/2004 4:51:58 PM: (error) in cmbBackup routine:[Microsoft][ODBC SQL Server Driver][SQL Server]. Cannot open backup device 'D:\sqltest\UnityDBBackUp.sql'. Device error or device off-line. See the SQL Server error log for more details. [Microsoft][ODBC SQL Server Driver][SQL Server]BACKUP DATABASE is terminating abnormally. number= 0.
Workaround
Disable CSA before running DiRT, then re-enable after the backup is complete.
Does this mean I have to disable CSA for scheduled DiRT backup??????
williamka Wed, 03/07/2007 - 10:10
Mike-
What version of Unity? 4.2(1)
Exchange or Domino? Exchange 2000
What Version of DiRT? 1.0.122
Administrator
lindborg Wed, 03/07/2007 - 10:40
  • Cisco Employee,
I believe the CSA folks provided a patched version somewhere along the way that removed the restrictions here, but I don't know that for certain (I'm not a CSA guy), but yes - it's been necessary to stop CSA to do backups since it will deny access to the SQL tables and registry branches the backup is trying to access regardless - this is the "permission denied" error you're seeing.
MikeTomasko Wed, 03/07/2007 - 10:49
You can get the latest version of the CSA for Unity here: http://www.cisco.com/cgi-bin/tablebuild.pl/unity3d
Does the Administrator account get permissions to the SQL or should another account be used for running DiRT? I use the UnityAdmin account and I have no problems with DiRT.
williamka Wed, 03/07/2007 - 12:21
I am running CSA 4.5.1 build 639. I'll disable CSA until we find a fix
