03-06-2007 12:29 PM - edited 03-03-2019 04:03 PM
I have a Cisco 1700 Series router pluged into a cable modem; connection type coming from the cable modem is DHCP. I have DHCP enabled on E0 on the 1700 but I am getting a lot of errors on the interface. Does anyone have a sample configuration of a 1700 E0 facing a cable modem for DHCP connectivity?
03-06-2007 10:06 PM
hi
what kinda errors you are seeing on the interface ?
Are you seeing any CRC/Input/interface resets on the interface ?
can you post the output of show interface e0 here ?
Also did you try changing the cable connecting both the router and the cable modem ?
regds
03-07-2007 06:32 AM
03-07-2007 06:54 AM
How can i view ur attachment?
03-07-2007 07:08 AM
should be able to open in paint or windows image.
03-07-2007 07:28 AM
Did u used the ip-helper address command to forward broadcast cause as u know a router doesn' t forward broadcast pakkets?
ps: can u please paste a screen-shot of ur start or running config
03-07-2007 07:49 AM
Here is the running config. I did not use the IP-Helper
------------------ show running-config ------------------
Building configuration...
Current configuration : 1360 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname PARADIS_1700
logging queue-limit 100
ip subnet-zero
ip dhcp excluded-address 192.168.1.1 255.255.255.0
ip dhcp excluded-address 192.168.1.2 192.168.1.99
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool PARADIS
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1 255.255.255.0
dns-server 68.9.16.30 68.9.16.25 68.100.16.30
ip audit notify log
ip audit po max-events 100
class-map match-all paradis
match access-group name PARADIS
policy-map Paradispolicy
class paradis
interface Ethernet0
ip address dhcp
service-policy input Paradispolicy
service-policy output Paradispolicy
half-duplex
interface FastEthernet0
speed 100
full-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 68.229.82.1
no ip http server
no ip http secure-server
ip access-list extended PARADIS
permit tcp any any eq 2869
permit tcp any any eq 10243
permit udp any any eq 1900
permit udp any any range 10280 10284
no cdp run
line con 0
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
password
login local
transport input telnet
end
03-07-2007 09:23 AM
Can you tell me what the configuration should look like?
03-07-2007 07:40 AM
The carrier is an electrical signal that Ethernet devices use to detect whether the wire is currently being used by another transmitting station.
The lost carrier counter increases each time a carrier sense loss occurs. This happens when the hardware is transmitting a frame onto the wire and does not see its own carrier wave on the Ethernet
03-07-2007 07:51 AM
We were testing is why the lost carrier; we kept switching cables and plugging the cable back into his existing Linksys when we needed internet back up
03-08-2007 01:46 AM
what kind of error are u getting from ur Ethernet interfaces?
