Cisco 1811, problem with NAT and MGCP
I am want to use an IAD in Internet with MGCP behind a Cisco 1811 using the C181x-adventerprisek9-mz.124-11.T image.
IAD(MGCP)-->C1811-->Internet-->Softswitch
<------->NAT
My IAD registers with the Softswitch but I am not able to establish calls with it.
After some tests and sniffing the WAN interface of my 1811, I realized that when trying to make a call, during the signalling, the IAD makes a response to a "Creat Connection" packet sent by the Softswitch. This response sent by the IAD is changed by the NAT (1811)and the packet goes damaged in this process; the layer 3 checksum of the packet goes to INCORRECT and the packet is discarded at the next hop. I did the same scheme with a PIX 515 and the call is established without any problem. I believe its a bug; does someone knows a way to go around this problem? This is my Cisco 1811 configuration:
version 12.4
hostname PRUEBAS
boot-start-marker
boot-end-marker
enable password
no aaa new-model
ip cef
ip domain name prueba
interface FastEthernet0
ip address 200.X.X.X 255.255.255.248
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
ip address 192.168.0.254 255.255.255.0
ip access-group ALL in
ip nat inside
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 200.X.X.X
no ip http server
no ip http secure-server
ip nat inside source list NAT interface FastEthernet0.3 overload
ip nat inside source static 192.168.0.150 200.X.X.X
ip access-list extended NAT
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended ALL
permit ip any any
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password cisco
login
transport input telnet ssh
line vty 5 15
password kas
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
