VPN client 'vpnclient stat' returns error: "...unable to communicate..."
Mar 6th, 2007
I use VPN client ( and Wireless WAN for the internet connection.
After connected to one of our customer's VPN site, I open the DOS command prompt and type the VPN command line: 'vpnclient stat'.
It returns:
"The application was unable to communicate with the VPN sub-system."
Then, about one minute later, 'vpnclient stat' will return a correct "VPN tunnel information".
I only see this VPN communication problem if I connect to a specific customer VPN site.
I made the VPN connection using command line: ipsecdialer /sd /c "My VPN"
Runs on:
Windows XP SP2
Cisco VPN Client (
1) What is the above 'communication' error message means?
2) Why I see this error about one minute right after the VPN connected, and it gets corrected by itself?
3) Why I only see this error if connected to one VPN site and not if connected to other VPN site?
2) How to fix it?
Any help is appreciated.
