VPN
Cisco CyberSecurity
Labels
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 373 Views
  • 17 replies
Hi EveryoneI'm using a trial version of ASAv and i believe it has full functionality but is limited in 100kbps. I'm trying to set up remote access anyconnect vpn which authenticates to our NPS radius server. As you can see in the radius debug, it see...
Hello everyone,Can you provide me with the eventid of the VPN failed logon on Cisco's devices?I couldn't find any examples and i wan't to create a brute force rule for it in my SIEM solutions.
CMPC by Level 1
  • 58 Views
  • 1 replies
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 55 Views
  • 0 replies
Hello,When configuring SSL VPN, the default encryption type is "ssl server-version tlsv1.2 dtlsv1.2", which only shows up with a "show run all". In that output, I can also see that "ssl cipher tlsv1.2 medium" and "ssl cipher dtlsv1.2 medium" are disp...
Hello, we're running Cisco Anyconnect 4.2 NAC to connect to our VPN. I'm running into an issue where it's telling me that there are no network adapters. I've tried uninstalling/re-installing the network adapter drivers, Cisco NAC and I just can't get...
Hello, any help appreciated.I am having issues when trying to assign a different group policy to a user where the group policy contains a different client profile (XML) to the one used to connect in the first instance. This is what I am trying to do....
I have a DMVPN network with 4331 hub routers. Our HQ in Memphis has a hub on AT&T, and another on Lumen. Our New York hub is also a Lumen connection. All are 500Mb up/down. We have about 35 spokes around the US that peer to all 3 routers. BGP is the ...
I need to upgrade AnyConnect 4.10 because it is EOS on 3/31/24.  The replacement product is Secure Client 5.x.  Currently, users only have DART and NAM installed on their computers.1. Do I need to uninstall AnyConnect 4.10 or is that automatically do...
tachyon05 by Level 1
  • 2238 Views
  • 9 replies
We have clients receiving a "PKCS12 (PFX) without a supplied password" error while connecting to RAVPN using Cisco Secure Client (5.1.2.42). The headend device is FTD 3130.The full error is "There was an erro during initialization: PKCS12 (PFX) witho...
