VPN Client Error
Mar 6th, 2007
Hi, new to cisco stuff. First thing i had working on the new PIX 506e was the VPN. Set up the IP Pool, group, and username. Installed the client, worked great. Now that ive been playing around with figuring out rules, acl's, translations, etc. it seems the VPN client is inconsistent now. It sometimes will work, but usually it will hang at "securing communications channel". Cancelling the connection does not work, it just creates the second error shown in the log (see below). I then have to end the task via taskmanager, open the VPN client again, (icon pops up in the tray as locked, but does not see the remote network in any way) disconnect, and then exit to get my machine to talk to its local network again.
Here is the log:
Cisco Systems VPN Client Version 4.6.00.0045
Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client
1 15:44:39.600 03/06/07 Sev=Warning/2 CVPND/0xA3400011
Error -14 sending packet. Dst Addr: 0xFFFFFFFF, Src Addr: 0xA9FE0202 (DRVIFACE:1199).
2 15:46:06.876 03/06/07 Sev=Warning/3 GUI/0xE3B00002
GI GI_EnumPPP failed with error (FFFFFFFEh).
Thank you for any help you can provide. This will be the primary means for the few remote users we have to access the network from home, vegas, etc.
Maury
Edit:
heres another one
1 15:47:31.117 03/06/07 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: DeleteIpForwardEntry, error 87
Overall Rating: 3.5 (2 ratings)
Kamal Malhotra Tue, 03/06/2007 - 15:39
  • Cisco Employee,
I would appreciate if you could send the running configuration of the PIX so that we get an idea what is going wrong.
Kamal
Kamal Malhotra Tue, 03/06/2007 - 16:17
  • Cisco Employee,
Hi Maury,
It seems that you configured it through PDM.
Please issue the following commands on the PIX as it is expected to resolve your problem :
no crypto map outside_map interface outside
no crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
HTH,
Please rate if it helps,
Kamal
maury_macdonald Tue, 03/06/2007 - 16:22
Yes, i have configured it through the PDM, much easier for a noob like me. I'll punch those in and let you know how it works.
maury_macdonald Tue, 03/06/2007 - 16:26
PDM Ignored this command
access-list outside_cryptomap_dyn_20 permit ip any 192.168.60.192 255.255.255.224
Also, im struggling to figure out where this .60.192 address came from. My DHCP range for the VPN clients is .60.200 - .60.220
Kamal Malhotra Wed, 03/07/2007 - 01:59
  • Cisco Employee,
Hi Maury,
Don't worry about the .60.192 subnet. The pool range that you defined falls in this subnet so the PDM itself created the access-list using the subnet. Please let me know if the 3 commands I sent were issued on the PIX. If yes, did you try to connect after that and test?
Please let me k now how it goes.
HTH,
Please rate if it helps.
Kamal
maury_macdonald Wed, 03/07/2007 - 07:36
Well, like i said previous, the PDM Ignored that one command. And ive tried reconnecting, reinstalling the client software, and still same thing, securing communications channel.
Should i try running that through the console?
Maury
Kamal Malhotra Wed, 03/07/2007 - 07:51
  • Cisco Employee,
Hi Maury,
Does this problem occur only on one client or anyone trying to connect from any computer? Could you send the latest config again? I just need to see when you tried to paste those commands, which commands got issued and which got left.
Kamal
maury_macdonald Wed, 03/07/2007 - 08:05
No, i have tried it one two machines from 3 separate pulic IP's (if that even makes a difference) so far, and same thing for each.
Here is my running config
Maury
Kamal Malhotra Wed, 03/07/2007 - 08:21
  • Cisco Employee,
Hi Maury,
As per the config, none of the commands I sent to you got issued to the PIX so please issue the following commands via console, telnet or SSH (basically CLI) :
HTH,
Kamal
maury_macdonald Wed, 03/07/2007 - 08:29
when i enter the second command via the console, i get ERROR: unable to clear match address
maury_macdonald Wed, 03/07/2007 - 08:36
I rebooted the firewall, and entered the commands again, and they went through. going to test the VPN and get an updated config for you.
Kamal Malhotra Wed, 03/07/2007 - 09:34
  • Cisco Employee,
Could you capture the client logs and debugs from the PIX?
debug cry isak
debug cry ipsec
Kamal
Kamal Malhotra Wed, 03/07/2007 - 11:37
  • Cisco Employee,
Hi Maury,
For testing, could you please consider changing the software version of the VPN client. You can download the latest version from :
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/crypto/3DES/vpn/client/windows/vpnclient-win-is-4.8.02.0010-k9.exe&app=Tablebuild&status=showC2A
Please make sure that you remove the existing version first. Please also make sure that you don't have any 3rd party firewalls running like Norton Internet Security, McAffee Desktop Firewall or ZoneAlarm stuff.
HTH,
Kamal
maury_macdonald Wed, 03/07/2007 - 11:44
i guess i dont have the proper access. Probably havent spent enough money on cisco stuff yet :)
maury_macdonald Thu, 03/08/2007 - 12:22
Well, i think it may be solved partially, looks like its now just a client issue on my laptop here. Ive tried it on the other client with no problems multiple times. Could have been two issues seeming to be one, and those commands fixed one. I'm not too concerned about my laptop for now. Thank you for all your help!!!
Maury
