Mar 6th, 2007
iam using a boson sim to practice for ccna
i am connecting 2 routers point to point, banwitdth set, i can ping, telnet fine between them
e0 ( (
Router rip set networks,,
I have PCs off each router with default gateway
( dg (
(210.10.10..2) DG (
I cannot ping one pc to another successfully or from the router, all e0 so/s0/ interfaces are up as well as protocols.
Please somone tell me what i am doing wrong
MikeTomasko Thu, 03/08/2007 - 13:21
Can you ping a PC from the router that's on the same subnet? You said you can't ping from the router, but didn't say from the local router, the remote router or both.
what OS on the PCs? Did you make sure there's not a firewall on the PC that's blocking pings?
Did you try a TRACERT from one of the PCs and see where the trace stops?
pkentsmith Fri, 04/20/2007 - 03:19
Shouldn't the default gateways bt and to match your E0 interfaces on the router!?
