CE 500 - Login from network
Mar 7th, 2007
Hi, I've recently configured a Catalyst express 500 (24-TT), with management vlid 1, and a static IP-adress.
My problem is that I can't connect to it from my pc, that is connected on the same VLAN.
I get the Logon screen, enters the credentials, and then it's stops.
Is this a known bug, or what am i doing wrong?
kcoley Wed, 03/07/2007 - 16:55
The CE500 does not support telnet. Use a web browers to open the GUI configuration tool that allows for easy management. Also, you can manage multiple swiches such as the CE500 via a free Java based application on your PC called CNA (www.cisco.com/go/networkassistant)
cristian.munoz Fri, 03/09/2007 - 11:07
I had problems with my browser. Some version not support IE 7 or Mozilla.
PS: please remember to rate posts!
